Cura 3.6 Scaling menu bug
dwoods
Posted · Cura 3.6 Scaling menu bug
When trying to use the menu scale option, I found that with Uniform Scaling NOT checked, a change to X value would still cause
a change to Y and Z. If I click on Transform menu and return to Scale menu, you can see the Uniform Scaling is CHECKED.
Closing and restarting did not fix the problem, however other times it seems to work s expected.
        • 24 replies
