Plug-ins not saved
Erik_Es
Posted · Plug-ins not saved
I have been using Cura 14.7 for years now. Does almost everything I want...
Now I have started to give Cura 3.6 a try. Quite like it, but there is one major bummer: the plug-ins are not saved together with the profiles (as is the case in 14.7) and neither are they saved in the 3mf project files. I use ChangeAtZ a lot, for instance to change print temp at specific places during printing. So that has to be different for each model. Is it really so that the inclusion of plug-ins in the saved profiles has disappeared ? And if so, can this PLEASE be reinstated ?
