Hi @Mibix, I tried slicing your file with my version of Cura and I don't get those travel lines.
This could be because of the changes I have made to the combing. Those changes are not yet in Ultimaker's Cura so if you want to try my releases they can be found at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0.
My releases can be installed alongside the Ultimaker releases and will not interfere with them.
BTW, don't use the sharpest corner z-seam alignment for symmetrical objects. It's better to use the user defined z-seam position hint and specify suitable x/y valyes so as to position the seam where you want it. That may help remove some of those travels that cross the gap.
1
Mibix 0
CE3_Rocket_Shot_125_combing_retract_on_layer_change.3mf
Forgot the project file
