Heat Bed Sensor Error
Posted · Heat Bed Sensor Error
Hello,
I'm getting a Heat Bed Sensor error (ER02) on my Ultimaker 2+.
I went through the steps of check cable connections, and swapped the TEMP 1 and TEMP 3 connections to troubleshoot the problem.
When I put the heat bed sensor into TEMP 1 and try to heat the nozzle, the error result is> Error Stopped Temp Bed Sensor
When I put PT100 into TEMP 3 and try to heat the bed, the error result is>Error Stopped Temp Sensor
What does this mean...?
All the connections and wires look fine. Nothing seems loose.
Need this printer working.
Please help.
Thank you.
