When printing Facilan Ortho with a 0.40mm nozzle we recommend to use the settings listed below. It is important to allow the printed layers of Facilan Ortho to cool down before add the next layer. In Cura, under Cooling, increase the Minimum Layer Time considerably (60 sec minimum, highly dependent of model size and complexity) and enabled Lift Head. Alternatively printing several models to allow for the layers to cool down enough.
Overhangs and thin, stand-alone walls may improve be supported with water-soluble PVA. This is especially true for small/thin details on a larger print, see picture below.
The piece of code that needs to be in the initial part of the Gcode is M302 S60 which allows for extrusion at temperatures below “normal” printing temperatures, in this case down to 60 °C.
Facilan Ortho (0.4mm nozzle, Larger model)
Nozzle Temp: 140-130 °C
Build Plate Temp: (no heating)
Adhesion: Adhesion sheet (supplied in the Ultimaker advanced printing kit) or similar.
Cooling: 100-80%
Print Speed: 30-15 mm/s
Wall Thickness: 4 lines
Support Material: Compatible with PVA
Settings for AA0.25, AA0.4 and AA0.8 nozzles is currently in testing and should be available in the Cura Marketplace soon.
Thank you very much, I'll give those settings a go. The parts I am trying are small and delicate, only about 8mm high and they don't print perfectly with PLA.
Our pleasure, please let us know the result 🙂
ElogioAM 0
Hi There!
Hope that helps.
