Oh, great. That solves it then.
Thank you.
Gunther
I have my "UMO 2+" with mark2, which is beside the wooden frame an UM2..
And then I only have one interface. Can Duet be used with Tinker mark2 firmware??
No, you can't run Ultimaker firmware on a duet board, but you also don't want that. the duet firmware is really good and open for easy modification, you'll just have to setup a few macro's for the tool change g-code. probably others have done it already...
There's plenty benefits to use a duet over an Ultimaker board, to name a few, the machine will be network connected, and have newer stepper driver which make the machine much quieter.
ultiarjan 1,209
You also need to adjust the size in the printer, but in the "Tinker mark2" firmware you can just do this from the menu, so I don't think that should be a problem.
edit; and I assume you use UM2 electronics because you have it laying around already? otherwise it's probably smarter to look at a Duet3D board...
Edited by ultiarjanLink to post
