Posted · Adding a printer with custom FW to Cura
I have a CR-10S with Marlin 1.18 on it now, which I have set up using Tacblades FW found on Thingiverse.
My question is, do I need to change the way the printer is added to Cura? I have it down as the standard CR-10S with Marlin as the G-Code flavour.
I checked the manual and it doesn't specify.
I assume that's right?
Thanks in advance.
