fbrc8-erin 296
Try this fix for the fan bracket issue. It's soft metal; if it gets bent out of 90 it doesn't close well; you should be able to bend it back to 90 degrees with a little force.
2
sajawors 0
Nevermind. The printcore housing won't close all the way (the magnet won't engage) so I'm using the rubber bands to hold it closed so it doesn't fall open during a job and one of them got caught in the hole the pole goes through the carriage. Just means I need to figure out the housing problem sooner rather than later.
