Dim3nsioneer 559
Just for the case you did not yet find this post: http://umforum.ultimaker.com/index.php?/topic/2454-cura-13064-plugins/&do=findComment&comment=21281 (post no. 8)
It is a version of the FlowThermostate-plugin which works with Cura 13.06.04+
You might also try this updated Wood-plugin: https://github.com/Dim3nsioneer/Cura-Plugins/raw/master/Wood1.1.py
However, you should consider it as beta...
kochen 0
I got the same problem with the Wood plugin, it doesn't change the temp, as far as I can see, the gcode is completely the same with or without the plugin enabled..
