Posted · Strange Ringing Issue
I'm new to this forum and look forward to be part of this community.
I'm having a weird printing issue that I'm not how to describe.
It looks like a ringing problem, but also not...
When there is a feature on the wall of a print it seems to translate to artifacts elsewhere on the print but on the same layers.
In the pic attached, the artifact to the left (circled) is due to a blind hole on the other side of the part. The other walls of the print looks nice and smooth (but there is no features on those walls).
I had true ghosting issues before and it's now much better after putting the printer on some hard foam.
I did a cube print just before this one with only 1 shell layer and hollow inside when I calibrated my extruder (thought that might be the issue) but it printed perfectly.
I'm using Cura 3.6.0.
Print speed was 60mm/s with outer perimeter at 40mm/s.
Printed with PLA.
I made sure all the belts are tensioned and the bearings are good.
Any suggestions would be most welcome.
Thanks
