Wall surface looks weird
Ghadeer
Posted · Wall surface looks weird
Hello fellow makers
I was printing with TPU 95A the other day, and the print surface looked non-smooth with a bit of gaps between wall layers (see pic below). I used the built-in settings for TPU in Cura but I made few changes:
Layer height: 0.15 mm
Wall line count: 1mm
Infill density: 10%
Retraction minimum travel: 0.7 mm
Print speed: 40 mm/s
Layer adhesion: Brim
Did anyone face this issue as well? what do you think the reason could be?
