2 Different/Confusing Print Errors
smemily
Posted · 2 Different/Confusing Print Errors
When printing with Ultimaker 3, I have had a lot of errors in which the brim will slowly start to lift off from the build plate creating lifted bumps which get bigger as the print continues.
I decided to wait and see if the print would come out okay in the end but only got a little further before the print head seems to lock/makes a sound which makes me think its somehow stuck before continuing to print in the wrong place.
I have tried calibrating the print bed several times to solve the first issue but have had no luck and have no idea what is causing the second problem.
Any ideas?
