Sorry, spoke too soon. Seems like it has other weird issues (which do not happen when Line Width is set to 0.39mm).
Edited by petervanwesten
Yes, that's not good. Unfortunately, that OS X version is rather out of date now but I can't build a working OS X release anymore on my ancient Mac Book. If you could share that model, I could at least check my current implementation to see if it can handle that better now. It's still a work in progress.
Here is a simple test object
Anything I can do to help you build one?
Maybe I can do the build for you?
I don't have much experience with Python... but might be able to follow some instructions 🙂
PS: I am using the "Sidebar GUI" plugin. On that outdated OS version of yours, it causes the slice/save dialogue to double up:
Might want to check if that is also solved in your latest release.
11 hours ago, petervanwesten said:Anything I can do to help you build one?
That's a kind offer. Building Cura isn't terribly difficult. The best place to start is to clone Ultimaker's cura-build-environment repository (https://github.com/Ultimaker/cura-build-environment) and build that and then build the cura-build repository. If you can get through that, it's then a simple step to build my version.
11 hours ago, petervanwesten said:Might want to check if that is also solved in your latest release.
I don't mess with the UI so it should work OK.
burtoogle 514
That's true but, unfortunately, it is necessary right now. Cura doesn't really handle walls that are not an even multiple of the wall line width wide terribly well. And thin walls and the wall gap fill are also problematic for Cura right now.
You may wish to try my master branch build (Linux and Windows only) that has a different implementation of the thin wall and wall gap filling so it could work better for your model. My builds can be installed alongside the Ultimaker releases without conflict. You can find them at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
