Clay 3D Printer
Joseto
Posted · Clay 3D Printer
Hi!
I'm building a Clay 3D printer from scratches. As a controller I used a TinyG, and Coolterm to comunicate with it.
I wanted to use CURA to develope the Gcode, because this is the software I use normally as a slicer for my 3D printers.
I have had the following problem:
When I set the gcode flavor, all of them have the extruder axis named with an E, but my controller reads it with an A. Is there ayway to change this name?
Thanks you!
