Thanks for answering, nallath.
I ended up doing this to create a cube that touches the buildplate:
s = size / 2 dtb = distance_to_buildplate verts = [ # 6 faces with 4 corners each [-s, -dtb, s], [-s, s, s], [ s, s, s], [ s, -dtb, s], # a = x-yz [-s, s, -s], [-s, -dtb, -s], [ s, -dtb, -s], [ s, s, -s], # b = x+yz [ s, -dtb, -s], [-s, -dtb, -s], [-s, -dtb, s], [ s, -dtb, s], # c = xy-z [-s, s, -s], [ s, s, -s], [ s, s, s], [-s, s, s], # d = xy+z [-s, -dtb, s], [-s, -dtb, -s], [-s, s, -s], [-s, s, s], # e = +xyz [ s, -dtb, -s], [ s, -dtb, s], [ s, s, s], [ s, s, -s] # f = -xyz ]
where "distance_to_buildplate" is the position in the Y axis of the cube when you click on the model, which is the same thing as the distance from the cube the ground.
nallath 1,113
There are two things you can do; You can either create longer squares with the MeshBuilder and move them down a bit (since they are places based on their center) or you can scale the model (check the setScale function of the SceneNode that contains the meshdata)
