Posted (edited) · Repeated , consistent under extrusion
Can someone help me understand this please.
Have 4 failed prints where the problem occurs roughly after 5 mm build height.
Looks like it just doesnt feed the filament in the same rate as before.
I thought I had a grinding problem stopping the feed but last fail looked ok on the wire. (been changing retraction parameters and infill to reduce retractions)
Cura preview looks good too
Nozzle isnt clogged, I can feed manually after a failed print and start a new print without doing anything, first 5 mm still works fine.
Edit :Its like its keeping the flow rate from ironing the planar surface while moving upwards...
Edited by AndersK
