Posted
· A bunch of things PostProcessingPlugIns and debug
PS:
- "def __init__(self) -> None:"
init doesn't return None, it actually doesn't return anything, so at some point having the "-> None" will break your code.
- if you make your function-entry comments into strings, python will automatically use them as the function's __doc__ property, so that they are documented by help(function_name, and will the life of anyone who looks at your code as well as your own a lot easier 🙂
> ipython
Python3.7.1(default,Dec102018,22:54:23)[MSC v.191564 bit (AMD64)]Type'copyright','credits'or'license'for more information
IPython7.2.0--An enhanced InteractivePython.Type'?'for help.In[1]:def getSettingDataString(self):...:""" You may either use the normal getSettingDataString function or the getSettingDataStringWithInfo
...: the latter will add a comment setting in which you can enter any relevant information
...: you want to insert at the beginning of the GCode file """...:pass...:In[2]: help(getSettingDataString)Help on function getSettingDataString in module __main__:
getSettingDataString(self)You may either use the normal getSettingDataString function or the getSettingDataStringWithInfo
In[3]:
If you'd like to experiment with gcode without always having to remember the gcode names ... it's very preliminary, I've only been hacking at it for a few hours: https://github.com/kfsone/pymcode. If you have a UM3, there's a "ultimaker3.py" script you can run that drops you into an ipython repl with "um3" configured as a connection to your printer and "ops" having all of the command aliases. Or you can then type "repl()" and it will go into a mode where you can basically either type '"M104' to send raw gcode, or you can just use the command names:
kfsone 5
PS:
Cmd> "M105 Cmd> set_bedtemp 65 Cmd> "T0 Cmd> set_hotendtemp 200 Cmd> wait_hotendtemp 190 Cmd> go
There's a "help" command to list the repl commands.
