no the thin walls are not shown in the gcode.
The thin-wall stretchlet is too thin for Cura. You should use the solid version, and set the top/bottom to 0 as well as the infill. This gives you a nice outside single line wall.
David... your my hero ;-)
Ian :-)
Dim3nsioneer 557
Just being curious: do you see the missing parts in the Gcode view of Cura? I had once a print where some thin walls (0.8mm if I remember correctly) were missing as well. They did not appear in the Gcode view as well.
