Copy all changed values to all extruders
mechamecha
Posted · Copy all changed values to all extruders
Recently bought a UM3 to go with the UM2 that I've had for a number of years. Still playing around with Cura settings to get the best prints when using dual extruders. What hasn't helped is I've noticed that Cura doesn't seem to "copy all changed values to all extruders" when using that right-click option, so I've had to go through each setting and use "copy value to all extruders" instead which is a real pain. I'm using Cura 4.0.0. Hopefully this will be fixed soon?
    • 3 months later...
    Posted (edited) · Copy all changed values to all extruders
    Once you save the changed values to a profile they are not changed values anymore, so they are not recognized by "copy all canged values to all extruders" (I think...)
    I'm also having this problem with Cura 4.2.1.
    Could there be an "copy ALL values to all extruders" option added?
    Edited by kleinmueli
