Posted · Weird unnecesary travel
I made test object and I`m facing weird travel moves that are not even marked in cura as travel. best to see a video
this is in cura 4,tried all combing setting, cura4.1 is even worse.
vase mode solve the problem but not alway is possible to use vase mode.
thanks for help
    Minimum wall flow setting solve the problem Thanks a lot.
    I have additional question: why it did the second run over the print with 0 flow? is it because of design of the shape?
    Cura always prints non-thin walls as a pair of lines, the inside and outside edges of the wall outline. Thin walls are handled differently.
