does anyone have an idea why the sliced model results in 0.4mm less height @0.2 layers?
all top and bottom layers seem to be present according the preview
So i made a 11mm box and sure enough when i sliced it at 0.2 layer height it had 54 layer(which equates too 10.8 mm)
The only setting i could find that effected this is the slicing tolerance, exclusive gave 54 layers, inclusinve gave 56 layer, middle gives the correct layers at 55.
ElWiz 0
Just tried Cura 4.1.0 stable and it's the same behavior
