Insert M80 prior to bed heating
Biff
Posted · Insert M80 prior to bed heating
Cura 4.1
G-code flavor: Marlin
How to cause M80 to place prior to Bed Heating
;FLAVOR:Marlin
;TIME:1014
;Filament used: 1.43077m
;Layer height: 0.3
;MINX:88.834
;MINY:96.542
;MINZ:0.3
;MAXX:130.024
;MAXY:123.458
;MAXZ:18.9
;Generated with Cura_SteamEngine 4.1.0
M140 S60
M105
M190 S60
M104 S190
M105
M109 S190
M82 ;absolute extrusion mode
M80 ;Power Supply On
G28 ;Home
    You need to put the bed and extruder placeholders in the machine start Gcode
    eg
    G21 ; set units to millimeters
    G90 ; use absolute positioning
    M80 ;power supply on
    M104 S{material_print_temperature_layer_0} ; set extruder temp
    M140 S{material_bed_temperature_layer_0} ; set bed temp
    M190 S{material_bed_temperature_layer_0} ; wait for bed temp
    M109 S{material_print_temperature_layer_0} ; wait for extruder temp
    G92 E0.0 ; reset extruder distance position
    obewan,
    tkx, not only did that make the difference,  I went looking for and found the parameters listings.
    Didn't know it existed.
    Game On!
    Biff
