Posted · 2+ Extended serious layer shifting
Ok so, Ive been using an Ultimaker 2+ Extended recently and after a big print Ive found a serious issue that has make the entire print useless.
It seems that, around 81mm or so, the entire print layer has shifted, massively, as can be seen below.
65584114_2439801259630910_5805557983207266333695_461992864359592_16848801766110665764668_421801178666026_90169767821500765718135_713663452423739_404085536695359
What are the probably causes of this issue? Is it just the servo belts that potentially need tightening? Or is there possibly another issue that I need to resolve?
I also got an ER05 code, which has the Z-axis being broken, but I think that was due to me running out of filament, the other prints that I have done seem to be fine, but none of them approach the 80 mark
66176308_369460787262187_795534208441044
In addition to this issue, another piece that I printed is ugly and spotted with extra filment. Is there a particular cause for this? Or is it just because of neighboring prints?
For context, im using 0.8mm extrusion of 3mm PLA, 20% infill
Thanks in advance!
