No "Infill before walls" checkbox
Posted · No "Infill before walls" checkbox
Always happens that the "Infill Before Walls" option gets turned off by either of three other settings, Infill Extruder, Infill Density, and/or Inner Wall Extruder. No matter what I do to either of these three setting I dont get the IBW checkbox to show. When I open a new project it shows then, so I try to use those exact settings in the project im working on, but the box still never shows. I am thinking there are other settings that affect this visibility, but they are not documented in Cura. Any help appreciated.
    Has this BUG been addressed? I am convinced Cura is getting jacked up somehow and this setting gets permanently hidden. It's visibility is checked in settings, but it still does not show regardless of any pre-requisite setting (according to the documentation that is) I guess the documentation might be missing a setting that affects the Infill before walls visibility.
