Posted · Cura won't slice multiple objects
I'm trying to slice an STL file to have 9 multiples of the object however I am only able to slice a maximum of 2 in one go. What could be stopping the software from allowing more objects to be sliced?
The following settings were used: PLA for the primary material with a nozzle size of 0.25 mm, PVA for the secondary material (support) with a nozzle of 0.4 mm. Layer height of 0.1 mm, thin walls enabled.
Thanks in advance,
Maria
Bone_IslandRemoval_-25_FEFree (2).stl
