Understanding Start Code Tab
spac3man
Posted · Understanding Start Code Tab
Hello.
First, let me say Great Work! I'm a new user coming from other slicing software and Cura has made a significant improvement in the quality of my prints.
The transition to Cura was straightforward except for how the start code is determined. I first set the machine to use 1 extruder and modified the start code to reflect the behaviour I wanted. That worked just fine. Then when I set the machine to 2 extruders, a new start code was listed as Start2.gcode. I assumed that this is where I should put my modifications to use for a dual extruder print. However, when I save and look at the gcode file, it is still using the first Start.gcode and not the Start2.gcode.
Can someone explain this behaviour? What do I have to do to get Cura to use either code?
Thanks in advance and once again.... Great Work!
Space.....
    Right now, Cura uses the start.gcode for prints with 1 color, and start2.gcode for dual color prints. For prints with dual-extrusion-support-material it uses start.gcode which is a bug. (fixing it right now)
    I've written a plugin that takes a nominally single-color file and switches extruders partway through. How can I get it to use the start2 gcode (to properly prime the 2nd extruder) instead of the start gcode?
