Posted (edited) · Strange line in every print that extends beyond build volume
So I tried printing something today, did everything as usual, but out of nowhere, my printer tried going outside of its build volume. Thinking I may have made a mistake, I simply replaced the items in Cura, sliced, and tried again, with the same result. When loading the actual gcode into cura, I noticed a strange line in my print, that I can't explain, as you can see in the screenshot I attached. This line is only there when I load the gcode in cura, it's not there after loading a model and slicing it, hence why I'm thinking it has something to do with Cura. I tried loading older gcode files, that I have already printed successfully, and these don't have this strange line.
I also tried creating a simple cube in Fusion 360. Slicing that in cura and loading the gcode resulted in the exact same line showing up. I wonder if this is an issue with Cura's slicing, or with Fusion 360 adding an invisible element?
Any help would be greatly appreciated, since I'm very much dead in the water due to this weirdness.
Edit
I reverted back to 4.1.0, which doesn't produce this weird line. Maybe this is useful info for somebody?
526998250_Screenshot2019-08-1113_54_22.thumb.png.b8b2e0da5bd2e42005d97a73d1e5e4f9.png
Edited by Timmiej93
