Hello @joecap5, I'm afraid that is what you get when you use the thin wall setting in Ultimaker's Cura. There are two ways you can get around this:
1 - turn off the thin wall setting and then reduce the line width until the wall is printed using "non-thin" walls. You should then ensure that the wall overlap compensation is enabled and set the min wall flow to something > 30%. This may require the wall line width to become thinner than optimal and so you would be better off going for option 2 (read on).
2 - download and install one of my Cura releases (Linux and Windows only) that does the thin walls differently and it should handle your example with ease. These releases can be installed alongside the Ultimaker releases. You can find them at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0 There's a README file in there that explains how my Cura differs from Ultimaker's
Hope this helps.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
burtoogle 505
Hope this helps.
