Ah yes, I probably should have mentioned I've had a play with that setting but I found it knocked ~10-20% off the print time but not the 50%+ I'm after for it to be worth it. I really need it to also print some of the perimeter layers at the larger layer and nozzle size with just the external wall to be the finer nozzle. - Ideally using the larger nozzle for 95% of the print (inc outer perimeter layer) and just switching for the 5% that needs the finer nozzle such as printed hinges and threads.
nallath 1,101
I think this was possible in 2017. Check the "Infill Layer Thickness" setting.
It doesn't exactly do what you want it do do, but it's almost there. This setting allows for the infill to be printed at a different layer height than the rest of the print. So if you're doing the print at 0.1 mm, you can do the infill at 0.2 (but not 0.15, as it needs to be a multiplier of the main layer height).
Alternatively, if you have a dual extruder machine, you can also set it up to print the infill with the larger nozzle and the outer wall with a smaller nozzle. This wont save you a lot of time for smaller prints (as the cooling down / heating up also takes time) but it should make it faster for larger prints.
