Nozzle Size Question
ShopGeezer
Posted · Nozzle Size Question
So what does decreasing the nozzle size do?  If I change from .4mm to .25mm nozzle the print line width will be narrower but the line height will still be the same as that entered in Cura. I would need more passes to get the same wall thickness using the .25mm nozzle. This would make the print take longer.  So what is the advantage of using a smaller nozzle? In what circumstances would you want to use a smaller nozzle?
    The obvious reasons are:
    - for small objects or for objects with fine details in the x/y direction
    - for objects with thin walls
    And there are even smaller nozzles than .25mm...
    If you need some inspiration:
    http://thedailymini.com/daily-mini-interview-miniature-3d-printing-lance-abernethy/
        • 27 replies
