10 minutes ago, DivingDuck said:are you sure having enough material between your threads that's matching your printer setting and nozzle?
It's not the part, everything is on the picture above. I'll try to explain better.
The gray outline the arrows are pointing to is the size of the actual part. The sliced one is 1mm smaller due to the -1mm horizontal expansion set. Otherwise the sliced part would cover the gray ghost outline. On the top, inside the cube I set +1mm horizontal expansion to override the base settings, but it does not. On that half the sliced lines should extend beyond the ghost model.
I've chosen the 1mm to make the problem visible, the value I print it with is 0.15 and the part is printable, just too tight on one thread, too loose on the other.
DivingDuck 79
Not knowing the measurements of your part and Cura setup, are you sure having enough material between your threads that's matching your printer setting and nozzle? For me it looks like you try to print a wall between your threads that do not match with the resolution of your setup and so there is not enough material to print.
Usually it's a good idea to attach the part in question as an .3mf file. The file include your Cura setup and model so that someone who want's to help can take a closer look and give you a much better answer.
