On 10/14/2019 at 12:05 AM, DaveWave said:I have a tall model that I want to have 100% infill for the first 10 cm (height) of the print, then drop back to whatever the global setting is. How can this be done?
>use the support blocker ( 6th icon on the left side missing a tool tip ) to generate a generic cube model OR add a model of your own for custom shapes
> select the model you just placed
> select Per Model Settings ( 5th icon down on left side also missing tool tip )
> change the mesh type to "Modify Settings For Overlaps"
> hit the "select settings" button and add the "infill density" option
> set the infill density as required ( in my case I needed 100% infill for a section of my model )
> move the model/mesh to where you need it.
The end result is a model with different infill densities as specified by the overlapping of the modified "support blocker" model/mesh.
3
oparrott 0
I'd like to know about this too. Any success?
