ghostkeeper 105
I see you describe two problems that can both be fixed with settings:
- Minimum Infill Area will close small gaps in the top skin. This way, instead of stopping just before the small gap, it'll just continue printing skin over the whole gap. It can save some time at the cost of more material. This answers your main question. It's not as brute force as your proposed solution, but only applies to small gaps in the skin where it's needed. Increase this setting to maybe something like 10mm^2 for your model.
- Ironing Inset is a distance that Cura will keep between the edge of the ironed area and the edge of the top surface. If you reduce that to 0, the influence of those letters will not nearly be as big.
I hope those solutions are sufficient for your case. I think the first solution is a better solution in general than what you've proposed.
burtoogle 515
Have your tried increasing the top skin expand distance setting?
