7 minutes ago, gr5 said:Your issue is that you aren't squishing the bottom layer enough. Squish is the most important thing to keep your part sticking to the build plate. If it was properly printing the bottom layer they wouldn't come apart like you show in the photo.
I don't know how to alter the leveling on a prusa but if it has auto leveling maybe you need to turn that off and stick with manual leveling.
Hi my first layer is normally working fine, it works with same settings in cura when the object is touching buildplate, this problem appears only when i put the model to corner so first layer contains only supports
Edited by janahorova
gr5 2,234
