Log cura errors
Daniel26
Posted · Log cura errors
Hello,
I did some modifications on a plugin.
Now the cura only plops up shortly.
How can I log the errors or start cura on the command shell to see where it crashes?
OS is Windows 10
Regards
Daniel
    Ok, it is NOT plugin related. I uninstalled, deleted the program folder, all folders under c:\Users\user\AppData, restarted, installed new, restartet....I see a cura icon for a half second, then.....nothing. In taskmanager a cura process is shown.
    The folders in c:\Users\user\AppData are NOT created....cura seems to hang.
    But where does it hang? And why?
    The system log shows also nothing cura related.
    But cura was running on that machine till yesterday so I think it is not a compatibility issue...
        • 27 replies
