Plugins HowTo
Daniel26
Posted (edited) · Plugins HowTo
Hmmm,
I try to reengineer a plugin and looking for a funktion which I can't find neither in uranium nor somwhere else in Cura:
Application.getInstance().getMainWindow().screenshotImages()
Can anybody help me to find it? Or the replacement in newer versions of Cura?
Regards
Edited by Daniel26
    Ok, Nice.
    What is this plugin doing?
    But isn't there anywhere a howto?
    When is a plugin called?
    I wan't to include a preview of the model with specific g-codes to the G-Code-File.
    Edited by Daniel26
    Posted · Plugins HowTo
    That is what this plugin does. Use file -> export and select UFP as the output format. Inspect the saved file as if it were a zip file.
    Hmm, no. It seems not to be the same. The UFP creates a bundle. I wan't the code in the gcode-file.
    Butr I think it will bring me a step further.
    Thanks.
    But when will a plugin be executed? Everytime I slice a file? Or can I configure when a plugin will be executed?
    The UFPWriter plugin is an OutputDevice plugin. Those are documented in an example here:
    https://github.com/Ultimaker/UraniumExampleOutputDevicePlugin
    Sorry, the UFPWriter is a MeshWriter plugin. There is no example plugin for that. But the UFPWriter plugin itself is fairly simple, code-wise. A MeshWriter plugin has a "write" method that you override. This method is called when you save a file in the format the MeshWriter plugin is configured for. Other types of plugins have other ways they are called. What sort of plugin you want to write really depends on what you want it to do.
    The simplest type of plugin to start with is an Extension plugin: https://github.com/Ultimaker/UraniumExampleExtensionPlugin
    Edited by ahoeben
    I wan't  to execute the plugin everytime a gcode file is being created.
    Best would be a point in the settings to activate it.
    What are the qml files for?
    I'm not totally nw to python, I'm also writing apps with pyQT in business. But I don't have any clue how to write a plugin for cura.
    QML files describe the UI. They are pretty integral parts of creating UIs with Qt and conversely pyqt.
    You could act every time a gcode file is written, sent to the printer via USB or the network like this:
    class SomePlugin(Extension):
        def __init__(self):
            super().__init__()
            application = CuraApplication.getInstance()
            application.getOutputDeviceManager().writeStarted.connect(self._onWriteGcode)
        def _onWriteGcode(self, output_device):
            # do things
            pass
    Alternatively, you could listen to the state of the backend:
        def __init__(self):
            super().__init__()
            application.getBackend().backendStateChange.connect(self._onBackendStateChange)
        def _onBackendStateChange(self, state):
            if state == BackendState.Done:
                # do things
                pass
