Thanks. That's what I thought. I just wanted to make sure.
- 2 years later...
If file size is an issue - you can use Arc Welder which intelligently converts endless strings of G0 & G1 codes into G2 & G3 codes. Cuda has an Arc Welder plugin which does this post-processing conversion.
But Cura doesn't do it natively - I can't see that you'd gain much if Cura did as you'd get pretty much the same result at the end.
https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/ArcWelderPlugin
- 1
Thanks Posital. I have been using Arc-Welder since it's beta, and of course I have added the Cura Plug-in. I asked the question here before Arc-Welder existed.
Wayne
ahoeben 1,992
Cura does not support curves. It only loads polygonal models which don’t have true curves; only estimations of curves by multiple flat polygons.
