BUG? Cura Post Processing Plugin Errors
mkrmec
Posted (edited) · BUG? Cura Post Processing Plugin Errors
I have an Ender 3 Pro and I have been experiencing trouble with multi color prints.
I've tried:
Pause at height: (retraction doesn't work in this case, is there a retraction limit? 30 works, but 300 doesn't)
Pause Layer: 10
Park Print Head X: 0
Park Print Head Y: 0
Retraction: 300
Retraction: Speed 50
Extrude amount: 50
Extrude Speed 3.3333
Redo Layers: 0
Standby Temp: 0
Filament Change: (if you select layer 11 it will stop at layer 10 to change filament, just WHY? It also pushes filament OUT just before the initial retraction and creates a mess on the print)
Layer: 11 (I want to enter 10  because I wanted a change at 10)
Initial retraction: 30
Later Retraction Distance: 300
X Position: 0
Y Position: 0
One would think somebody else noticed these problems before me?
What am I doing wrong? I can't wrap my head around it.
EDIT:
I just tested new settings that print great, but I still have to retract the filament out by hand since the retraction doesn't work to 300.
Pause at height:
Pause Layer: 10
Retraction: 30
Extrude amount: 100
Redo Layers: 0
Standby Temp: 0
CE3_supportCUBE_filamentchange.gcode CE3_supportCUBE_pauseatheight.gcode
Edited by mkrmec
        • 1 reply
