Posted · Request: Cura Connect - Display needed filament
So right now when you queue up print jobs in Cura Connect it just displays the part, filament type, print cores and build plate. But it would be real nice and handy to also display the filament needed in weight and meters like how Cura does when you slice the file.
Sometimes i can have parts in a queue for weeks so its very easy to forget what amount of filament is needed to help you pick if you will need to change spool or not mid print, why the filament sensor on the S5 is great, it don't help if it runs out a hour after i go from the printer and can not get back to it for 6-7 hours to swap the spool.
          • Heart
        • 4 replies
