thanks for the quick reply.
Yes. I've done it for the small Models and they are enbedded in the big model.
If I will set the Wall of the big model to zero than I'll have a result in the contact area
between the small models and the big model. But the big model has then no
wall at the outer conture.
DidierKlein 730
If they are different models and if i understand the question correctly you might select the per model settings (left button bar) and change the wall settings for the models you want
