Posted
· Need custom flow rate added to material settings
On 12/6/2019 at 4:27 PM, mk153smaw said:
Flow rate for filament needs to be added to the:
Preferences - Materials - Information section
This would help immensely!!!!!!!! I conduct a flow test for every spool of filament and it would be amazing if I could put that flow calibration result in the material section so I do not have to manually adjust the print settings each time I change a roll.
Seriously.... You have a preferred print temp and bed temp selection that gets transferred to print settings.
If you go to the market place in Cura, you will find a plugin called "Material settings" this add's extra print settings to the materials list.
Posted
Thanks for the find. Was looking for just this thing as only 1 of my filament seems to over extrude. I've measured and set it like all my other filaments. But I guess it's the small price to pay for getting a random filament from somebody. Thanks
Carla_Birch 116
stevvie 0
