Temp Sensor problem - some clarification needed
cigoler
Posted · Temp Sensor problem - some clarification needed
I've followed the instruction from here; https://ultimaker.com/en/resources/19484-stopped-temp-sensor following a problem when starting prints of a temp sensor problem. So i've swapped Temp 1 and Temp 3 and heating the bed doesn't bring up an error - but it also doesn't increase the temperature of the bed it stays stuck at 27 degrees. When I then try heating up the nozzle I get bed temperature error.
The instructions aren't super clear about this. Does it mean it's the sensors fault or the main board?
