Support blocker broken?
twlum
Posted · Support blocker broken?
I am trying to use Support Blocker to do custom infill percentages. As soon as I scale the support blocker block, it goes completely skew and becomes a mess. Using Cura 4.4.1. Any help is appreciated.
    Posted (edited) · Support blocker broken?
    Solved. The model "came in" to Cura at some weird angles due to how it was designed. I took the STL back into Fusion (I think you could use Tinkercad as well) and reoriented the model. Once that was done, I brought it back into Cura and support blocker behaved like normal.
    Edited by twlum
    Added Solved in case bots need it.
        • 6 replies
