Yes, I tried to move it from tha controller and it only moves up and not down.
Could you try to change it with another steppermotor (so put the z axis in the slot of the x axis) and try if the z axis is the problem or the driver?
1 hour ago, Job_van_gennip said:Could you try to change it with another steppermotor (so put the z axis in the slot of the x axis) and try if the z axis is the problem or the driver?
Ok, I changed the Y,Z wiring and it seems that the Y doesn't work correctly now.
So, that must mean that the motor has a problem?
Edited by panosnaIf it is the bed that keeps acting strange the problem is in the motor. If the problem shifts to a different motor it is the stepper driver. I am not fully clear what you mean with the Y does not work.
Job_van_gennip 23
Have you tried to move it from the controller to check?
