UM 2+ buildplate stops about 22 mm lower than printhead
Posted
· UM 2+ buildplate stops about 22 mm lower than printhead
You mean that it happens when you start the build plate calibration, at the first step? That's normal and intended behaviour. Use the menu wheel to adjust the rear position and the thumbscrews for the front left/right position.
Posted
Thanks Robert, I kept turning the thumbsrew in the back (instead of the menuwheel); that clearly didn't work. Because of this stupid question I'd better create a new userprofile. Thanks again.
IRobertI 521
multi 0
