Find out at what temp your heat block boils water. Set it to 90C, then increase by 5C until it boils. It should boil around 95C to 105C. If outside that range something is wrong with your temperature measurement system. It could be the wiring, it could be the small electronics board on you print head. It's usually not the thermocouple - but sometimes even that can go bad.
If the print head is just always 20C hotter than you could live with it and always print at 180C instead of 200C. If you go any lower than 180C you will occasionally go below 170C which halts the movement of the extruder.
Note that there is a spare cable for the temperature measurement. You can just switch to the other connector (at both ends - the print head and the board underneath).
gr5 2,229
