Use formula to set value
DeeZ
Posted · Use formula to set value
Hello.
Is it possible to use formula to set value?
For example, I'd like to set 2 layers for support roof thickness but there is used mm, and when I change layer height I need find and change it too.
I can't set formula in field, I tried to set  directly in file but doesn't work (I used user file in .local/share/cura/4.4/quality_changes/).
support_interface_height= =layer_height*2
Is it possible?
    Setting it in the quality_changes should work, provided that the definition also has a setting_function (This is a known bug, we simply havent gotten to fixing it yet)
        • 4 replies
