Posted · Cura 4.4.1 Layers Compatibility Mode
Hello.
I have Ubuntu  16.04.6, Cura 4.4.1. And layers preview works in  "compatibility mode".
In options "Force layer view compatibility" is disabled.
Why I can't see other layers (speed, line type).
PS: I have 3 monitors 1980x1080+1980x1080+900x1600 (sum display is 4860x1600)
stderr.log
    In stderr.log it shows the detected OpenGL version
    2020-02-03 08:46:34,521 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: OpenGL Version:  3.0 Mesa 18.0.5
    It's saying that the version is 3.0, you need version 4.2 to get the full functionality.
    If you run glxinfo in a terminal what do you get in the ExtendedRendererInfo section, for example, this is what I see
    Extended renderer info (GLX_MESA_query_renderer):
        Vendor: Intel Open Source Technology Center (0x8086)
        Device: Mesa DRI Intel(R) HD Graphics 520 (Skylake GT2)  (0x1916)
        Version: 18.0.5
        Accelerated: yes
        Video memory: 3072MB
        Unified memory: yes
        Preferred profile: core (0x1)
        Max core profile version: 4.5
        Max compat profile version: 3.0
        Max GLES1 profile version: 1.1
        Max GLES[23] profile version: 3.2
    Hello. Mine is:
        Vendor: X.Org (0x1002)
        Device: AMD BARTS (DRM 2.43.0 / 4.4.0-171-generic, LLVM 6.0.0) (0x6739)
        Version: 18.0.5
        Accelerated: yes
        Video memory: 1024MB
        Unified memory: no
        Max core profile version: 3.3
        Max GLES[23] profile version: 3.1
    Posted (edited) · Cura 4.4.1 Layers Compatibility Mode
    Great! thanks for Idea.
    My hardware supports higher versions of openGL. I use this command to run:
    MESA_GL_VERSION_OVERRIDE=4.5 MESA_GLSL_VERSION_OVERRIDE=450 ./AppRun
    Edited by DeeZ
    Sorry, yes, I missed that. OK, well, there's your answer because in there it says:
    So the accelerated GL is version 3.3 and it needs to be 4.2 or greater.
    I am also using Mesa version 18.0.5 so it's not as if your drivers are old. Maybe your hardware simply doesn't support a later version of GL?
    The internet says that the AMD Barts is capable of supporting OpenGL 4.4 so I guess you need to update to a later driver?
