Ultimaker Tough PLA Bad Diameter
Travis7s
Posted · Ultimaker Tough PLA Bad Diameter
This morning I discovered my print had failed, it looked like a clogged nozzle which I thought was odd for PLA. Upon further review, there was a small section of filament that actually measured 3.2mm diameter. It worked its way all the way up the bowden until it got completely stuck at the extruder. This is genuine Ultimaker filament and I had used around 2/3 of the spool without issue, and it looks like the rest of the filament after the bad section is fine too. Has anyone else experienced this?
    Check if your front fan (the one in the door) is running when the printcore is hot. Maybe it is blocked by something.
    This fan is important to keep the hotend cool where it should be cool.
