cura 4.4 wont download on mac (running catalina) (tried beta too)
kirstynellen23
Posted · cura 4.4 wont download on mac (running catalina) (tried beta too)
I believe that this can be worked around by using this command in a terminal
xattr -d com.apple.quarantine FILE
This removes the quarantine attribute from FILE that is causing the message you see above.
Google com.apple.quarantine for more info.
    In Finder do a right click and then choose Open.
    You have to do this only for the first time, then a normal double click works also.
